I'm working on a merc classic fifty 45hp for a customer. I have never worked on one of these before.I work mostly on yamaha outboards.Anyway,<br />the motor runs great at idle but will not run at any other speeds.On these motors when u prime the engine up to where the primer bulb gets tight should gas come out of the carb throats &<br />main air jets. The only time i see this is when<br />the needle is stuck open or when the float is cracked and will not close needle to seat.Both carbs are doing this is why i am not sure about going into them yet. If anyone can help please reply.
