Hi there<br /><br />My 1976 Blueband Merc 850 is currently idling around 1500 rpm and then at 1000 rpm when in gear. I've read that this might be a bit to fast and might be damaging my gearbox. I adjusted the idle screw on the side of the motor and set it back to 1000 rpm when not in gear. I still idles about 1000 rpm when in gear with this new adjustment but when I take off and try pull a skier is has a serious loss of power. I adjusted the idle back to the original 1500 rpm and I have all the power back and it runs great. Can anyone shed any light on this problem? Thanks<br />Nial
