--------------------------------------------------------------------------------<br />Mariner 150hp Ser#0D124111<br /><br />In process of removing the oil injection due to stripped gear on the crankshaft. Disconnected the purple wire from the lubalert to the terminal block to stop the oil alarm from beeping. Upon doing this it also took out the overheat alarm. How do I wire this up correctly so that the overheat alarm will work? I appreciate all the help I get on this site. Any reply is appreciated.
