freshwater clam
PuckHog
I just recently purchased a '78 Mercury 800 which was stored on a boat in the water (a lake) for most of it's life. As with any new used motor, first thing I set out to do is replace the impeller. When I removed the lower unit, I found a fresh water clam in the cavity near the exhaust!<br /><br /> My question- Because of the constant contact with the water the lower unit is pitted (heavily in places). The seals seem fine and the gear oil is free of water. Are there issues with the pitting I should be worried about?
Clams Canino
Re: freshwater clam
Don't steal my routine. :D <br /><br />Then again, in my world, a fresh water clam is an outboard such as you bought that refuses to run. :) <br /><br />If you wish, you outta sand/clean the lower real well and paint heavily (3-4 coats) with Mercury Phantom Black to stop any further putting. If it don't leak don't fix it.<br /><br />-W
PuckHog
Re: freshwater clam
Thanks for the advice. It'll look better as well. How do I get your 'link and sync'? I want to get this motor set up right from the beginning
Texasmark
Re: freshwater clam
I bought a '65 Mercruiser in like '75 that had spent it's life at a marina with the lower unit submerged. Actually, when I answered the ad and looked at the boat, it had at least a foot of water inside at the stern. Really doubt that the guy ever pulled it and serviced the gear train. I gave $1600 for it and after I found out what I bought, that was wayyyyyy too much.<br /><br />I completely redid the boat including full paint, new floor, floatation, carpet, engine and outdrive complete overhauls......the oil in the engine was yellow, I mean really yellow.....my first experience with yellow oil and why it's yellow....then there was that crack down the side of the block where it had frozen at least once.<br /><br />In short all the lower unit was pitted and I could see that I would have had problems with the sealing surfaces on the rebuild. What I did was to take JB Weld and a file(s) and remake the sealing areas.<br /><br />After the overhaul, we used it for over 5 years with no breakdowns. It was an 18' aluminum Starcraft and not very "Bass" fishable so I sold it to 3 boys (and bought a bass boat) and the last time I heard they were still using it.<br /><br />Neither of us had any problems with the repaired sealing surfaces. If you don't have JB weld, any metal impregnated opoxy that sets up without voids (where you can file...machine it) should work.<br /><br />Also, if you have a machine shop nearby, they could probably save you a ton of time by machining the surfaces for you after you glue them up.......be sure the surface is clean down to fresh aluminum before you apply the build-up material so it will stick good......and be sure you don't get any bubbles in it. <br /><br />Good luck,<br />Mark
