upper vent screw stuck mariner 150
ranimated
I have 1998 Mariner 150 and I'm trying to change the lower unit grease but I cannot get the top screw out. I have tried WD 40 and if I torque it any harder I'll round it out and never be able to remove it. Please help, how do I get it out??<br /><br />Randy
andy6374
Re: upper vent screw stuck mariner 150
Get a proper sized punch or small flathead screwdriver and tap the corners (in the proper direction), this should loosen it up. Try some PB blaster its better then WD40.<br /><br />If you end up rounding it out there are other options...dremel or a screw/bolt extractor.
papasmurf
You could also try an impact driver. I use it quite often.
ranimated
Thanks for the advice. I'm going to borrow a friend's impact driver. If it doesn't work, I may be back.
