imported_mike_clarke
- Jan 6, 2006
- 2
I have a 1991 75HP Mercury with power Tilt/Trim.<br /><br />I have not used it for a few months and today the Power Tilt would not move upwards (but down is fine). The motor humms but no movement. I swapped the solenoids but no difference. The fluid is at the correct level and the manual override screw is tight. <br />I turned the manual override screw back one-to-two turns and the motor would then go up slowly but would not go down.<br />Is this likely to be a worn valve or o-rings or possibly air in the system?
