  #1
Old May 31st, 2002, 07:12 AM
butlp butlp is offline
Default Yamaha Trim Ram Leak
For the first time I foolishly stored my 1989 90hp Yamaha tilted up this past winter. I had the boat shrink wrapped but had to trailer it home and can only do that with the motor up.Now one of the trim rams is weeping very slightly and I have had to top up the oil reservoir. The other trim ram and tilt ram are fine.I contacted my local dealer to see if I could get a seal kit for the trim rams and if I could hire/borrow any special tools needed. They want $245 for parts and $280 for labour, but suggested I leave it and see if the leak stops when I get the boat in the water and start using it more.I don't have my service manual here in Mexico, but from memory I'm sure with the correct tool you can pull the end caps off the trim rams and replace the seals. Anyone performed this work and can advise how difficult it was.I have seen Auto Transmission Conditioning Fluid in the auto parts stores that supposedly stops leaks. Has anyone tried this and would recommend it before pulling the T&T apart.Thanks in advance,Peter
  #2
Old May 31st, 2002, 07:23 AM
rbu rbu is offline
Default Re: Yamaha Trim Ram Leak
I don't think I would try the auto tranny fluid with that leak stopper.Have you tried to tighten the end cap? Yamaha says you need a special tool but there are ways around that.
  #3
Old May 31st, 2002, 07:58 AM
rbu,It's leaking around the ram so I'm not sure if tightening the cap will help. I was hoping that the seal or "O" ring would swell if I used the tranny leak stopper.
  #4
Old May 31st, 2002, 08:47 AM
pthein pthein is offline
I wouldnt use the trany oil either. It is not designed to take the pressures of the tilt trim unit and it doesnt have the anti corrosions stuff that the Yamaha t&t has.I would also recommend that you just use it a bit. The t&t fluid sometimes swells and relubricates the innards and the leaks go away. Keep in mind that what you are seeind on the top of the unit is not the seal or o-ring, rather it is just the wiper. That $250 kit has a lot of small o-rings, check valves, etc. inside (estimate 50 pieces) and it takes a long time to r&r unit. The labor quote is not that bad. If you decide to do it youself you dont need a yamaha tool. Just go to the store and get a spanner wrench that has the right size ends. Dont use one that is not a perfect match on the end diameter else it will chew up the fittings.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Power Trim leak? (milky overflowing trim fluid) hal2814 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 December 5th, 2006 10:54 AM
tilt/trim hydranlic leak 91 /90hp yamaha tlrp imported_DANN Yamaha & Suzuki Outboards 5 October 14th, 2006 04:16 PM
97 Yamaha 90 hp trim leak down ccryder38 Yamaha & Suzuki Outboards 1 March 24th, 2004 12:27 AM
Yamaha 200 Oil Leak kenufish Yamaha & Suzuki Outboards 2 August 12th, 2003 12:52 PM
Yamaha 115 Tilt Trim Hydraulic Leak Bsmith69 Yamaha & Suzuki Outboards 3 January 15th, 2003 12:21 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
