My 'owners' manual tells me nothing - no around to help me - so I did what I thought was right.<br />Attached the rabbit ears & turned on water -<br />Disconnected the fuel line from the tank -<br />followed the fuel line to the filter -<br />disconnected the hose from the filter going into the motor -<br />started motor and let it run at a little high rpm -<br />inserted 'fogging can tube' into hose -<br />let it run until it stalled, used 3/4 can (no smoke at all came out).<br />Turned motor off - attached fuel hose tightly to filter & clamped it.<br />Turned off water & took off rabit ears.<br />That's it - did it right I hope???
