  #1
Old September 3rd, 2002, 11:14 AM
andymac andymac is offline
Default Yamaha 40 high revs buzzer sounding.
Hi The overheat alarm on my 1990 40hp Yam 2cyl 2 stroke sounds at high revs. Last season it sounded at much lower revs leading me to change the thermostat & sender, which has improved it considerably. It seems strange that it has now moved higher up the rev range. I'm wondering what I should look at next. I have a strong tell-tale which is always cool to feel. My prop is 11 1/8 x 13. My boat is 17ft with quite a heavy semi-planing hull that is designed to max at 18 -20 knots with 40hp. I have been told that a 10 pitch would be better but have spoken to someone with an identical boat & engine setup that does not do this. I run in an area that has strong currents but don't think that the currents plus prop load would make the engine overheat. It must be something happening within the engine. I don't have a rev counter but the engine is running quite fast, a good bit over 3/4 throttle before the buzzer sounds. It is happy to cruise at the pre buzzer level for long periods at planing speeds, then that last nudge of the throttle makes it go off. I can throttle back then get back on the plane again once the buzzer goes off, after a minute or so. Is there any point looking at a new water pump if I am getting a strong tell-tale? Anything else I should try? The engine runs perfectly apart from this.Thanks in advance.Andy
  #2
Old September 3rd, 2002, 11:34 AM
Kevin Hite Kevin Hite is offline
Default Re: Yamaha 40 high revs buzzer sounding.
I am guessing somewhat here. Is the tattletale coming directly from the impeller and letting you know if the impeller is working? If it is before the circulation system for the head, there may be some obstruction (salt or some other buildup) within the head passageways themselves. I would look at the thermostat to see if it is working properly and check the passages for any buildups that could cause a blockage....Kev_Alask***
  #3
Old September 3rd, 2002, 04:47 PM
Capt Ken Capt Ken is offline
Ensign
If I hear another, but its peeing a good stream, I'm going to choke someone. That stream is just saying," Hi there, I'm telling you the pump is pumping but its your guess how well I'm working". That stream is cut out of the herd of water before it goes thru the engine and that's why its always cool. As the "rubber" impeller gets older, it becomes less able to push the water at higher speeds and that's why the alarm is sounding. Keep pushing that thing to the limit and the next post will be " why is the compression low in one of my cylinders?"
  #4
Old September 3rd, 2002, 07:09 PM
John H1 John H1 is offline
Listen to the above post!!!!!! How long since your last pump? HereÂ’s an ideaÂ… install a good quality pressure gage permanently, NOT A TEMPERATURE. This will tell you what that little impeller is doing at a set RPM, and when it drops off, or later down the road (lake) when it starts to. Darn important gage if you stop and think about it. Be Safe John
  #5
Old September 4th, 2002, 12:55 AM
Thanks for the replies everyone.The tell-tale always being cool makes sense as you say. My local Yamaha agent told me to check this. He also discouraged me from having the impeller changed as he said there was little chance that this was the problem. It makes sense that the impeller would be less effective as the motor lay unused for 4 years.I will try replacing this. It's a total pain having to return motor to shop for repair I initially suggested. Maybe I could tackle it myself?Cheers
  #6
Old September 4th, 2002, 10:53 AM
Ensign
If that dealer really is a Yamaha dealer, then Yamaha needs to slap him upside the head. Yamaha reccommends changing the impeller every year but even I think that's too soon. Impellers need to be changed every two years. The first question out of his mouth when you said you was overheating should have been, "when was the impeller changed?" If your answer was two years or more, the impeller should have been changed first off.
  #7
Old September 5th, 2002, 01:05 AM
Capt KenI have the Yam service manual. It looks quite easy to change the impeller. Put unit in reverse, undo gear linkage, drop lower leg, take cover off the impeller & change it. Is it that easy, or is there anything I should be careful of? Is there is specific type of marine grease I need to lube the new impeller and how much should I put on. I would rather take it to the Yamaha shop but would probably loose the rest of the summer waiting for it to be done. What is a realistic time for a outboard mechanic to do this job in?CheersAndy
  #8
Old September 5th, 2002, 02:55 AM
Trent Trent is offline
Its an easy job. Less than an hour. Change the gear oil also while your at it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
yamaha F225 high pitched alarm sounding otim49 Yamaha & Suzuki Outboards 4 November 11th, 2005 10:19 AM
2001 Yamaha 90 oil tank leaking and buzzer sounding klarest Yamaha & Suzuki Outboards 0 September 25th, 2005 03:07 PM
Buzzer sounding, Motor oil resevoir not refilling dousterhout Yamaha & Suzuki Outboards 2 July 23rd, 2005 05:59 AM
buzzer is sounding red700cat Johnson & Evinrude Outboards 4 May 18th, 2004 06:48 PM
Yamaha 40 high revs buzzer sounding. andymac Yamaha & Suzuki Outboards 0 September 3rd, 2002 11:12 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
