  #1
Old August 24th, 2002, 09:53 PM
pcarter pcarter is offline
Default 70 hp yamaha steering cable problem
I have a 1986 70hp yamaha which came new on an 86 skeeter bass boat. On my last trip out after turning to the left to circle back to the dock, the steering wheel popped, and I lost my steering. The steering wheel will turn the motor to the right, but turning left just feeds out cable through an assembly on the steering column. I have tilt tube steering connections.
  #2
Old August 25th, 2002, 04:04 AM
nc4z nc4z is offline
Default Re: 70 hp yamaha steering cable problem
Sounds to me ,like the inner part of the cable is broken. When turning right the broken part pushes against the other end thats broken but turning left it is drawn out of the sleeve, and will come out at the steering assy.
  #3
Old August 25th, 2002, 04:44 AM
Trent Trent is offline
Time for a new steering system. About 130.00You will need to know if you have rack steering or rotary. Also look at the cable near the engine and see the length stamped on it.
  #4
Old August 25th, 2002, 05:40 AM
How do I change out the cable?
  #5
Old August 25th, 2002, 06:36 AM
FORCEfull FORCEfull is offline
It is very simple. Your new system will come with directions. I just changed one on my boat and it was very simple. I have done several and never had a problem.
  #6
Old August 25th, 2002, 10:46 PM
I've determined that I have a tube mount rotary steering cable system. I'm trying to remove the cable myself. The cable is disconnected from the rotary piece under the steering wheel, but I'm unable to disconnect it at the motor. The nut on the outer cable is off at the tube mount,and the tube mount is unbolted from the opposite side of the motor. The pin that goes through the motor turns freely, but the cable won't unscrew. The motor is mounted down low so that I'm unable to pull the pin on out of the motor. To pull the whole assembly out, the motor would have to be hoisted up 6-8 inches. Is there some way to get the cable out without hoisting the motor.
  #7
Old August 26th, 2002, 01:00 AM
Nope.....Your going to have to pull the engine to replace the cable.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
replace steering cable on yamaha 90hp at hiker Yamaha & Suzuki Outboards 1 May 21st, 2006 04:57 PM
Steering Cable Problem CindyM Boat Topics and Questions (not engine topics) 7 April 9th, 2004 05:40 PM
Problem With Removing Steering Cable martinb Boat Topics and Questions (not engine topics) 4 November 27th, 2003 03:47 AM
77 55 hp Evnrde steering cable problem ruffduff Johnson & Evinrude Outboards 2 July 26th, 2003 12:58 PM
Problem connecting steering cable to motor ozzy9970 Johnson & Evinrude Outboards 1 April 30th, 2003 05:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
