  #1
Old August 24th, 2002, 07:27 PM
Tim Laurent Tim Laurent is offline
Default 1987 yamaha 115 oil injection system
Here is my problem,The oil tank inside the engine compartment drains down after two or three days sitting with motor tilted down ,oil leaks thru the lower carb onto ground. When tank is refilled to run motor with hosepipe, oily water and white smoke blows out of the prop for 5min. till it's clear and no oil or smoke is present. motor runs great.
  #2
Old August 25th, 2002, 01:16 PM
Capt Ken Capt Ken is offline
Ensign
Default Re: 1987 yamaha 115 oil injection system
The older engines didn't have the inline check valves on the oil lines. These prevented this problem when the oil bypassed the pump and flowed into the intake. You can get the check valves from any Yamaha dealer. They ain't much and will prevent this problem. You will need four of them and you just cut the lines between the oil pump and the intake and stick them in.
  #3
Old September 3rd, 2002, 07:48 AM
rbu rbu is offline
I had that problem too. There are check valves in the oil pump. Sometimes they need to be reseated. I would pull the pump, clean it out, and reseat the balls in the check valves.
  #4
Old September 3rd, 2002, 04:51 PM
Ensign
Leave the oil pump alone. The pump isn't a owner serviceable item and there isn't any check valves in the pump. Just a little cylinder that goes round and round with a hole that lines up with the different oil holes. The inline check valves were added with later models to address this problem.
  #5
Old September 4th, 2002, 06:19 AM
rbu rbu is offline
Ken, I have a 1988 V6 Yamaha and there ARE check valves in the oil pump. One of them became stuck in the open position causing oil to flow through the pump and into the intakes.
  #6
Old September 4th, 2002, 10:43 AM
Ensign
Where I was coming from rbu, is we don't need owner's messing with their oil injection systems. Those check valves never worked well and that's why Yamaha starting installing the inline check valves. If an owner goes and messes with the oil pump and doesn't do it right, the engine is trashed. We don't need that problem. The inline check valve is an easy solution that won't cause problems with the injection system and can be owner installed.
  #7
Old September 4th, 2002, 11:48 AM
rbu rbu is offline
Have you read some of the other posts? There are guys messing around with more than just the oil injection I hear what you are saying Ken. That's a smart move to install inline check valves. I'm just trying to share some of the experiences and solutions that I have had. I know that I have been stumped and frustrated more than once.Anyway, I hope this guy gets his problem fixed.
  #8
Old September 7th, 2002, 10:11 AM
Thanks for the info. I priced the check valves (10.45 each) Can I disconect the 4 lines on the intake and see which one or ones are leaking ,or just add the new valves. There are splice connectors in each line , do I replace them with check valves.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 Yamaha 115 oil injection problem imported_tigger Yamaha & Suzuki Outboards 3 August 5th, 2006 10:41 PM
Oil Injection System mbradley Johnson & Evinrude Outboards 11 January 19th, 2006 03:18 AM
1987 EVINRUDE VRO OIL INJECTION jonathan W moore Johnson & Evinrude Outboards 2 April 25th, 2004 03:52 PM
1987 70 HP Yamaha, oil injection CT-Kurt Yamaha & Suzuki Outboards 3 September 5th, 2003 06:53 AM
1987 90hp Yamaha-oil injection fishingbear5 Yamaha & Suzuki Outboards 3 March 1st, 2003 03:14 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
