  #1
Old August 4th, 2002, 11:12 PM
letsbarbq letsbarbq is offline
Default Whats the 3 functions of the yamaha dual multi function gauge?
On one gauge it has 3 functions when you hit the mode button. mph, time, trip something? my question is the trip something? That is the 3rd function that I do not understand clearly. This gauge also has the gas level in the right side in a vertical stack column style. I was wondering if this might be the trip to empty ? is this yamaha's version of the flo-scan fuel computer or fuel flow managers? Anyone with any help would be appreciate. I also have the other gauge to go with this. Its a pair. this one has the rpm, oil level, temp alarm. I was wondering how it goes as well. I understand the rpm part. I see the oil levels and where it is indicating but I was wondering if it will flash red or yellow or green or anything if the oil is low or full or half way? thanks again.
  #2
Old August 10th, 2002, 11:12 AM
shaggyyqq shaggyyqq is offline
Default Re: Whats the 3 functions of the yamaha dual multi function gauge?
The trip is the distance travelled for this particular trip. To reset it to zero just press both buttons at the same time. It will then begin recording the distance travelled again. As for the indications on the tach, if the oil level is low or not reaching the engine they will flash and an audible alarm will sound. Hopefully this helps.
  #3
Old August 11th, 2002, 11:02 AM
Forktail Forktail is offline
Ensign
Sorry, no flow scan computer or trip to empty features. This is a seperate gauge.The RPM gauge shows trip time, actual time, battery level (in volts), and fuel level.The trip time begins when you start out on your trip (key on) and can be reset by pushing the two buttons together. The actual time can be set to your time zone. The fuel level indicator is basically a standard fuel gauge showing empty to full.The RPM shows a trim/tilt level, oil level alert, temperature alert, total hours on motor and a hour counter that can be reset by pushing both buttons together.I love these gauges.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2001 yamaha 250 efi, Multi-function gauge and tps question . bernieb Yamaha & Suzuki Outboards 4 April 20th, 2007 04:41 AM
Yamaha Multi-Function Digital Tach question dpfundst Yamaha & Suzuki Outboards 18 June 7th, 2006 06:19 AM
Yamaha Multi-function guages jsnyder Yamaha & Suzuki Outboards 8 August 17th, 2004 05:47 AM
Yamaha LCD multi function gauges jmacd99 Yamaha & Suzuki Outboards 6 May 28th, 2004 06:05 AM
Yamaha Multi-Function Fuel Gauge Troubleshooting Mantee1 Yamaha & Suzuki Outboards 2 January 4th, 2004 04:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
