I purchased a 1987 150 Merc V6 XR2 this spring and after several attepts to fix an intermittent miss, decided to rebuild the fuel system and check the ignition. I have removed the carbs and fuel pump and have to re-build them yet. I removed the flywheel and the stator and noticed the trigger had a fair amount of free play both sideways and up and down. The play is in the range of 1/16 of an inch or more all ways. The plastic covering on the wiring coming out the bottom has a crack in it but I cant find a number or date on the trigger. I do know that the previous owner used to pump the throttle/shift lever back and forth 8 times before cranking, he seemed to believe that it would prime the engine. I told him that it didnt do anything and he seemed surprised as the previous owner told him to do it, so it has been done a lot. Would this practice have worn out the trigger from all of the constant turning. Should I replace it
