A service manual would be a great help for you
on this and many other service problems.
Try the library,the tab at the top of the
page,amazon.com,ebay,etc.
Mean time trace with a meter from battery to switch,switch to solinoid all hot side connections.Then all ground side connections.Be sure all switch connections are same as originals.A manual should give you a schematic
and a test procedure for the start circuit.
Boating industry of america color code chart at:
www.brokeboats.com,says red is unprotected
12v from battery,red w purple is protected 12v from battery,purple is 12v from ignition switch, yellow w red is ignition sw. to starter solinoid,Black w yellow magneto short to kill,yellow w black choke,black all grounds.
Hope this is some help.
