Well, guess what, I am one of the 2 guys that has the 703 remote on Ebay. Mine is the Pull to Open. You will need the opposite, and it's for the throttle, not the choke. See, this one when you push lever forward will Pull your throttle linkage inside motor. Yours will Push linkage, consequently you won't be able to use it, unless somebody knows if there is a way to invert internal levers on remote.
Val
