It sounds like the cable broke. You don't need to replace the whole remote unit, you can just replace the cable.
But to make sure you didn't break the throttle and shift parts at the motor or remote, dismount the control and take it apart. You'll see where the cables go in and hook up. Hopefully you didn't break the unit there. If all's ok then pull the cover off the outboard and you will be able to see where the cable hooks up there. Hopefully the carb linkage lever and shift lever will move with the cable unhooked.
