I had my engine fully tilted up the other day. I removed the plugs and sprayed some PowerTune in the cylinders. About 5 minutes later I tilted the engine down and white liquid came flowing out the carbs. It may have been only one carb, but I don't know. Does this sound like bad reeds, or is this normal (I doubt this)?<br /><br />If the reeds are bad it might be worth mentioning that the engine runs great in idle and at WOT. But the first burst to WOT (midrange) is a little bogged. i.e., it takes a couple seconds to get to WOT. However it won't do it a second time, UNLESS I troll or idle for a while. I heard of this symptom and leaky reeds before.
