  #1
Old April 7th, 2002, 09:19 AM
Fish lake Erie Fish lake Erie is offline
Default Yamaha 9.9 won't start when cold
I just purchased this used motor and it will not start when cold. I cleaned out the carb. I have to use my thumb as a choke until it warms up. Once it warms up the crankcase vacuum switch open up, the plunger on the top of the carb goes down and it idles and runs fine. How does the carb choke when cold?? I think this funcion is inop or plugged. Model F9.9LG, Code 6G9Lser. 302277Any help would be great!!!Thanks
  #2
Old April 7th, 2002, 10:37 AM
JB's Avatar
JB JB is online now
Default Re: Yamaha 9.9 won't start when cold
Howdy, FLE.I agree that the start-enrichment system isn't working correctly. Three bi-metallic vacuum switching valves sense temperature of the block and the ambient air and operate the starter plunger to enrich for starting.You said you have to use your thumb as a choke. Does that mean that you are restricting the air flow or that you are operating the "emergency knob" on top of the carb? The "emergency knob" is located under a plastic cover on top of the carb. With the starter plunger "UP" an extra passage is opened that allows an enriched mixture into the manifold.If your plunger is UP when cold, and drops down when warm, that part is working correctly. The passages may be plugged.Check this out. Be very careful not to seperate the plunger from the diaphram it is hooked to.Good luck. You will be very smart to get a manual before you tear into the carb.Red sky at night. . .JB
__________________
RED SKY at night. . .
JB
  #3
Old April 7th, 2002, 01:23 PM
Thank you for the quick reply. I was using my thumb to restrict the air to force a choke. the piston is up when cold and goes down when it has warmed up. Its's in the up position that there is no richness coming for the passage it is suppose to be coming from. I'll have to let the carb soak and hope what is ever blocking the passage becomes free. Ill have to thank the guy that stored the motor without draining the carb.I'll let you know how I make out.Again,Thanks for the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha EFI Cold Start TomS Yamaha & Suzuki Outboards 3 August 29th, 2006 09:15 PM
auto choke-cold start prob 90 hp yamaha hogfish1 Yamaha & Suzuki Outboards 25 February 23rd, 2005 05:09 AM
1990 yamaha 250 cold start question mike in boston Yamaha & Suzuki Outboards 2 July 12th, 2004 03:23 AM
1990 yamaha 150 cold start issue jmacd99 Yamaha & Suzuki Outboards 2 May 27th, 2004 08:22 AM
Yamaha 150 Cold Start SRHBass Yamaha & Suzuki Outboards 7 December 14th, 2002 07:57 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
