I'm swapping a 1980-81 20hp Merc Powerhead onto a 1976 20hp Merc engine (I'm assuming it'll work, same bolt pattern). My problem is that the 1980's powerhead is stuck on the midsection. I took out all 6 powerhead bolts and everthing inside the cowling holding it down then hooked the powerhead up to an engine lifter. Once it was about 3" off the ground me and my friend each stood on a side of the engine stand and waited, but the powerhead never seperated. That's about 350lb pulling on it! Is there a better way to get this thing apart?<br />Eric
