Re: Water pressure
Is this water pressure when in the water running, or on a flusher? Definitely Very Low for in-the-water pressure and you should see a drastic improvement after the new impeller is installed.<br /><br />Typically it's nice to see at least 5 psi at idle but it's extremely variable from motor-to-motor.<br /><br />10 psi running at speed is not unusual and hopefully you'll get more but again it depends on the design of the motor, the backpressure in the cooling system, the size of the impeller, etc.<br /><br />Most older motors would use a 0-15 psig gage so judge accordingly.<br /><br />The small-cubic-inch Merc 3's are very touchy about adequate cooling so be sure there's no other issues once you replace the impeller. These motors like to crack blocks if they're overheated so definitely stay on top of the cooling system!<br /><br />BTW make sure the lines for your water pressure gage are not clogged, as that'll skew your pressure readings too.<br /><br />HTH and Happy Boating.........ed
