How to adjust the carbs on a mercury jet sport
problems
I have an inboard 90hp mercury jet sport engine and need help tunning the carbs. I just purchased this boat and when I took it out to the lake it would hit 35mph with 2 people in it, when putting 4 people including myself it would drop down to like 10mph. I don't think the engine is running as strong as it should. Is the boat suppose to do that. I did not max out the weight or come close. I have read that this engine in a 15ft boat is suppose to go around 35-40 with no problems. Also when turning the boat it seems to almost come to a stop. Can someone help me out with these problems and help me understand why it is doing this. Thanks for all your help.
WillyBWright
Re: How to adjust the carbs on a mercury jet sport
You can only adjust the idle speed mixtuture. It has fixed main jets.<br /><br />Does the motor slow way down, or does it maintain RPMs as the boat loses speed? If the latter, I'd suspect a worn impeller and wear ring. Too much gap between them and it loses thrust. The 2 to 4 person symptom seems to favor this theory.
Zamboni
Yep, wear ring/impellor clearance is place to start. While your down there inspect the gasket/ride plate.
kenimpzoom
35 mph with a merc sport jet 90 is pretty good. What kind of boat?<br /><br />If you get overloaded the boat wont plane out.<br /><br />With 4 people, at 10 MPH, where were all the people sitting, how big were they, and did you try to move two of them to the front?<br /><br />Ken
