Have overheating problems with the engine at idle, the tell tale is very weak. Decided to strip lower unit off, replace impeller, gaskets, o rings and rubber riser tube. Pressure tested for leaks before re assembly, found no leaks. Re fitted lower half. Removed and chcked thermostat, works to specification. Also checked no blockages in engine waterways; via garden hose through riser shaft when lower half was split off, resulting tell tale was very strong.<br /><br />Tested engine in water barel after finishing rebuild. There is no tell tale pulled through at all, don't understand? Tested engine again with muffs on and some hose pressure, tell tale came through but was not sufficiently strong. Re stripped engine, repeated re build got same end results again. I am at a loss, can anyone advise?<br /><br />Engine tell tale had been extreemly strong after engine hits 1,500 rpm, nothing now. However idle tell tail has always been weak?<br /><br />Any help much appreciated as i'm running out of ideas.<br /><br />PS: ignition idle timing checked and is correct at 2 degrees ATDC, as is idle speet of 850 rpm.
