  #1
Old April 13th, 2001, 04:58 PM
Ed54 Ed54 is offline
Default Yamaha 1995 Fuel Air Leak HELP
I have a 1995 Yamaha 150 HP that has problems starting and running smooth. When running the motor the fuel filter bowl continuously goes up and down with air bubbles in it. Also hard to start. Must start it with the manual choke, not the electric choke.Should there be any air in the fuel filter bowl and/or should it stay full of fuel continously.If the fuel filter bowl is supposed to stay full of fuel at all times...do I have an air leak and how would I find the air leak.Thanks for your help in advance.Ed------------------ejkoch@sunco.comhttp://www.herbals-unlimited.com
  #2
Old April 14th, 2001, 04:19 AM
12Footer's Avatar
12Footer 12Footer is offline
Default Re: Yamaha 1995 Fuel Air Leak HELP
I noticed the clear fuel filter in my line does that too,and the engine runs fine. I think the pump has a tendancy to draw the fuel out of the tank as it needs it.NOT TO SAY, you don't have a leak. All it takes is one fish hook-sized leak to create those symptoms. There is a screen inside the fuel tank (if it is the plastic 3 or 6 gallon type). I doubt this is the problem,unless the problem went away when fuel line was switched to a different tank.But what you described is more than likely a fuel hungry condition. When it starts this crap, does the ball flatten out?------------------I'm no expert, but I DID sleep at a Holiday Inn last night!
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
  #3
Old April 14th, 2001, 04:31 AM
12Footer's Avatar
Jeeze.I wish they would enable edit.I didn't offer my .02 on how to determine a leak. If you have a air tester for the lower unit, you could pressurize the fuel line.Or a bike pump with an air gauge could work,dip the fuel line in water and check for bubbles.. But it would be cheaper and better to just replace the line (figuring your time and all). Is the old line "stiffer" than a new one? As they age, the fuel and sun turn these fuel lines brittle. Look closely at your existing fuel line while bending it sharpley. If you see any hairline cracks,crazed surfaces, or it feels stiff (yeah,yeah,don't go there)it should be replaced,along with the ball pump.------------------I'm no expert, but I DID sleep at a Holiday Inn last night!
__________________
right now."
  #4
Old April 14th, 2001, 07:45 AM
JB's Avatar
JB JB is offline
Howdy, Ed54. 12footer's advice is good. Here's a little more from a conservative old salt: Keep a spare fuel line, with pump and see-through filter, on your boat, along with your spare prop, impeller kit, tools kit, etc.,etc. You may never need it, but sometimes Murphy's law bites.Happy boating.JB
__________________
RED SKY at night. . .
JB
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
40 HP Yamaha 4 Stroke - Fuel Leak rutropa Yamaha & Suzuki Outboards 0 July 19th, 2006 11:26 PM
1998 Yamaha 150 - Slight Fuel Leak Starting Jilah Yamaha & Suzuki Outboards 1 June 20th, 2005 07:50 PM
2001 yamaha 4 stroke carb fuel leak alotto Yamaha & Suzuki Outboards 7 October 17th, 2004 09:16 AM
Fuel economy of 1995 Yamaha 175 Osprey Yamaha & Suzuki Outboards 6 July 10th, 2004 01:48 PM
Fuel leak 50 H.P. Yamaha 4 stroke Makky Honda & Tohatsu/Nissan Outboards 3 October 23rd, 2003 08:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
