Hi Chismac
Is it a single ram sys or a dual trim and a single tilt ram sys? It really needs a pressure test to see where the leak down is happening at. Also does it have hoses comming out of the pump or are the oil passages internal.
If you can't tell, I've not worked on one. They only make a few different styles and are verry close it design,so I'll try and help.
...have fun...corm
