Re: 1975 500E - Water in bottom two cylinders
Use heat (propane or MAPP torch will keep from melting things) on the bolts to help release them. What you don't want to do is snap off stainless bolts in alum block. Then you just about have drill out and install Heli-Coils or other type of insert. <br /><br />Last ditch if any bolt won't come out, drill out the bolt head and then when the exhaust manifold outer and inner come off, you may have enough of a 'stub' to grab hold of and get out.<br /><br />Regarding the lower crank seals, removing the powerhead will reveal the lower crankshaft bearing /seal housing assy. There are 2 seals pressed into this housing. I believe on your motor the lower crankshaft main ball bearing is pressed on the shaft and slip-fits into the I.D. of the lower housing assy. <br /><br />So, you remove the (3) bolts holding the housing to the block (remember to use care when loosening these, too). Then, you can use a puller plate, slide hammer, or similar pulling device, fastened to the threaded pulling holes in the bottom of the housing. An automotive harmonic balancer puller, with the center screw pressing against the crankshaft, will also work.<br /><br />What you have to be careful about is trying to pry on any of the (3) mounting 'ears' as they are somewhat fragile and could break if you pry the wrong way.<br /><br />Once you remove the housing assy you'll see an O-ring which must be replaced also. Punch out the old crank seals with a suitable tool and press in new ones. Note the direction the seals face as this is critical. "Lips down" on both. The solid face of each seal points up.<br /><br />Anyway, that's just an overview, your manual should run you thru the entire procedure. <br /><br />HTH & G'luck........ed
