i just bought a boat with a 1988 150 hp black max motor when i put the key in the ignition there is no alarm sound so im affraid the oil injection does not work is there a test to locate the buzzer a test to see if the buzzer works or a test to see if the pump is sending power to the buzzer i also herd that the lines need to be bled how do i do that and how do i verifie i did i correctly. could the buzzer be in the trottle
