  #1
Old January 9th, 2003, 09:26 AM
bill harris bill harris is offline
Default 40 hp03 yamaha on 5000# house boat(prop?)
Have factory prop should i going down or up on pitch
  #2
Old January 9th, 2003, 10:31 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: 40 hp03 yamaha on 5000# house boat(prop?)
Less pitch would be appropriate. Not sure what size you need. You might want to contact a Prop Shop for more info on where to start for that size boat.
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old January 9th, 2003, 10:49 AM
OBJ's Avatar
OBJ OBJ is offline
Hi 1bill....Hey rickd....think maybe a four blade prop might also be appropriate. Sounds like he's pushin' a lot with the 40hp.OBJim
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #4
Old January 9th, 2003, 12:36 PM
sorry didn't talk about lake restrictions at 40hp :o
  #5
Old January 10th, 2003, 03:11 PM
steelespike steelespike is offline
Very important, be sure your motor runs in the proper rpm range when you settle on a prop.
  #6
Old January 10th, 2003, 05:17 PM
Forktail Forktail is offline
Ensign
5,000 lb non-planing boat with 40 hp? Yikes. You'll want the smallest pitch and biggest diameter prop. This will give you the best thrust and highest rpm (you'll need it). Yamaha makes a 12 1/4 diam X 9 pitch for the 40. Trade the stock one in for that.2 or 4-stroke?FYI the 2-stroke 40 runs out at a max 5500 rpm with a 1.85 gear ratio. The 4-stroke runs at 6000 rpm with a 2.0 ratio.This means (without doing the calculations for you) that both the 2-stroke and the 4-stroke 40 produce about the exact same torque (WOT at prop) of 70 ftlbs. The 4-stroke's prop turns at a slightly higher rpm, so it would be slightly faster prop for prop, but hardly noticable. Since the 4-stroke's engine turns not only faster, but more often per revolution of the prop, it would probably have a better power and torque curve throughout the power band, especially under load. Ironically Yamaha's 4-stroke 40 is nearly identical in weight to the 2-stroke, so no performance lost with additional weight.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 115- prop for deck boat- moderator1 Prop Questions and Topics 1 June 26th, 2006 05:03 AM
What to look at when buying house boat ? papakevin Boat Restoration and Building 0 July 4th, 2005 08:51 PM
Anyone missing a house boat? blipship Boat Topics and Questions (not engine topics) 7 August 6th, 2004 07:47 AM
lifting a pontoon boat in a boat house jim turner rodgers Boat Topics and Questions (not engine topics) 4 April 29th, 2004 05:33 PM
house Boat mosseyz Boat Topics and Questions (not engine topics) 1 December 13th, 2003 05:31 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
