  #1
Old June 12th, 2006, 11:34 PM
D4no D4no is offline
Default Mariner 50 4 stroke model OG620526
This engine is running too hot.This Engine has always run a bit hot.Starts fine Idles fineTail tale ok does not increase with revs (have changed impeller the key is in place)Thermostat checked opens fineThe revs go down below 2000 after short time in forward gear in the water.Power head on idle to hot to touch.There appears to be water circulation.I,ve replaced the CDI I have also synchronized the carbuators.Is there something I am overlooking?
  #2
Old June 13th, 2006, 03:42 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: Mariner 50 4 stroke model OG620526
Welcome to iboats. Intennal blockage. You might be able to backflush. Remove the gearcase and set the motor vertical. Remove the thermostat and backflush thru there with a garden hose. You need it to flow freely back out the pipe that the water travels from the water pump. Backflush thru the pee hole too.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old June 13th, 2006, 11:34 PM
I have tried back flushing and there does seem to be some sort of blockage.Shouldn't the water pressure be as high as the pressure going out? Can I use compressed air?Can I try to unblock it using a stiff metal wire in the pipe that leads from the pump?YoursMarc
  #4
Old June 14th, 2006, 09:07 AM
Back flushing didn't work.I removed the power head and mid section.This exposed a mangled nearly completely blocked waterpipe seal.I guess now it's just a matter of replacing the water pipe seal and fitting everything back.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
99 MODEL 4 STROKE MERCURY 40 eskimo man Mercury & Mariner Outboards 3 April 7th, 2009 02:00 PM
Mariner Year and Model # Please w2much Mercury & Mariner Outboards 1 July 2nd, 2006 08:50 PM
Mariner Year Model rpeeples Mercury & Mariner Outboards 2 April 4th, 2002 05:04 PM
7.5hp Honda 4-stroke, Model # B75 MansellMan Honda & Tohatsu/Nissan Outboards 4 March 16th, 2002 11:07 AM
Old Honda 7.5hp 4-stroke, Model# B75 MansellMan Honda & Tohatsu/Nissan Outboards 0 March 12th, 2002 08:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
