Re: cleaning discoloration from hull
There are several excellent acid based cleaners (example; Zing) for scum line cleaning. Most are a hydrochloric acid solution with a detergent base. As listed above you can use muriatic acid from a hardware store if you can stand the odor. Although this stuff will work wonders on gelcoat, it will also burn your skin, eat metal painted or galvanized, and mark concrete.
