  #1
Old June 9th, 2006, 12:23 PM
Bleys19 Bleys19 is offline
Default Mercontrol Shifter and harnesses for 1970 mercury
1970 Mercury outboard, 50hpNeed new shifter, throttle, shift cables and Harnesses for my 1970 mercury engine. How would i tell what shifter today would work with my Engine and it must have a key start right, and how would i hook up the New Harnesses to this shifter box?What type of shift /throttles cabels? Read about different types of cable, 3300 or etc.
  #2
Old June 9th, 2006, 12:59 PM
sport15 sport15 is offline
Default Re: Mercontrol Shifter and harnesses for 1970 mercury
How many pins on the connector on the engine end? I found online the 8 pin connector and I think it was 20 feet of harness for $250 and about had a stroke. Google "mercury boat wire harness" and you should find the wire..I also found side mounts listed at hamiltonmarine.com.. What type of mount do you need?Make sure when you ask about cables that you tell who you get them from they will go an a mercury not OMC, apparently there is a differance.Good luck!
  #3
Old June 9th, 2006, 01:52 PM
I don't know what side mount i will need, i know i had a mercontrol shifter (1970) and i also don't know how to tell what one i will need if buy new. can't seem to find anything on wires i have that say numbers/info on them.
  #4
Old June 11th, 2006, 01:12 PM
ricksrster's Avatar
ricksrster ricksrster is offline
If you buy a new control, you can get an adapter for the wiring harness so you can plug it in your motor.
__________________
"Many of the greatest sailors were pukers."--Thorfinn Skullsplitter
  #5
Old June 11th, 2006, 01:25 PM
Rick, I can buy the same wiring harness that i need for the engine so how would i connect that to the new control? You talking about a adapter for engine or controler? My mercontrol seem like it was built into the Wiring Harness that goes to the Engine. So that what confusing me the most.
  #6
Old June 11th, 2006, 02:28 PM
ricksrster's Avatar
On the new controls there is a harness attached. The end plug is different from what you need. The adapter harness has an end that plugs into the new harness and the other end of the adapter harness plugs into your motor.
__________________
  #7
Old June 11th, 2006, 04:02 PM
So will i still need a old sytle harnesses or just a adapter harness that hooks into motor and controler and What Adapter Harness would i need?
  #8
Old June 11th, 2006, 04:17 PM
ricksrster's Avatar
A new adapter, which is actually a short harness with the new style of plug on one end and the old style on the other. It justs plugs on the new style harness. CDI/Rapair makes them or you can get one from a mercury dealer. The CDI would be cheaper. This is only needed if you want a new control. You still can find good used older Mercontrols at places like E-bay.
__________________
  #9
Old June 11th, 2006, 04:19 PM
ricksrster's Avatar
I'll show pictures of my set up to show you in a little while.
__________________
  #10
Old June 11th, 2006, 05:21 PM
ricksrster's Avatar
OK, Here's pictures. The first one is the new control. It came with 15' harness attached through the back. Next is the end of the harness at the back of the boat. The male plug is from the control harness and the female plug is on the adapter harness. Next picture is hooked together. A wire clip was supplied with the adapter to hold them together. I got the mercury Adapter harness. Next picture is the end of the adapter harness that connects to the motor.ket.com/albums/a258/Palmer54/HarnessSetup001.jpg[/IMG]It plugs in the side of the motor like this
__________________
  #11
Old June 12th, 2006, 12:04 PM
So what type of controler would i need? Just one with a key start or would i need other items with it?
  #12
Old June 12th, 2006, 12:51 PM
ricksrster's Avatar
you can get a mercury controller.Or you can get a controller that just shifts and runs the throttle. With the one that just shifts and throttle you can put a key with push choke in the dash. you can find the correct harness you need for the key switch from E-bay or elsewhere.
__________________
  #13
Old June 12th, 2006, 01:51 PM
I would like to get the Control with key/push choke, so would this one work with mine if i get adapter? http://www.iboats.com/mall/index.cgi...view_id=117291
  #14
Old June 12th, 2006, 02:04 PM
ricksrster's Avatar
Yes that will work with the adapter. If you do not have power trim, this will work. http://www.iboats.com/mall/index.cgi...e w_id=117285 You wikk have to order cables seperate, also.
__________________
  #15
Old June 12th, 2006, 02:09 PM
How should i fiqure out if have power trim?
  #16
Old June 12th, 2006, 02:15 PM
ricksrster's Avatar
back at yor motor, there will be a pump with hoses going to hydralic cylinders to tilt your motor.
__________________
  #17
Old June 12th, 2006, 02:24 PM
What info on the adapter so i know what to ask for or look up?
  #18
Old June 12th, 2006, 04:21 PM
ricksrster's Avatar
CDI makes an after market one available on line, but I don't know where. I bought mine from a local merc. dealer. I don't know the part no. but it is the adapter harness for hooking up a new control to an older motor.
__________________
  #19
Old February 12th, 2008, 02:12 PM
tgarrettiii tgarrettiii is offline
Quote:
I am having the same issue. Did you ever get this resolved and if so what did you do?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1970 Mercury outboard With Mercontrol Bleys19 Mercury & Mariner Outboards 21 May 30th, 2006 12:06 PM
question on mercontrol mercury 50 controls harryhood Mercury & Mariner Outboards 4 August 10th, 2005 05:16 AM
mercontrol shifter ragtopbilly Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 August 7th, 2005 03:04 PM
mercontrol shifter ragtopbilly Electrics, Electronics and Trolling Motors 0 August 7th, 2005 01:14 PM
Question about my Mercury Mercontrol Remote! just 2 questions please y2jericho Mercury & Mariner Outboards 7 April 3rd, 2003 04:41 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
