  #1
Old June 8th, 2006, 01:55 PM
lifeboatman3 lifeboatman3 is offline
Default 90hp Mercury slow out of the hole
I have a 1994 90hp 3 cylinder Mercury and it's not performing well. It's very slow out of the hole, when it gets to top speed it not to bad but still lacks that little kick you get. Also at about 3000rpm it seems to misfire below this it's O.K and above O.K. I would be very grateful of any help.Thanks
  #2
Old June 8th, 2006, 02:07 PM
05GlastronSX 05GlastronSX is offline
Default Re: 90hp Mercury slow out of the hole
just throwing out some thoughts here but it is possible that your boat is underpowered but we'd have to know what kind of boat its mounted on. Also, what prop pitch are you running on there now? maybe the bad hole shot is because the pitch is too high.
__________________
2005 Glastron SX 170
2005 150 Mercury XR6
1999 fisher V-1667 utility
1992 Mercury 40 classic (4cyl)
  #3
Old June 9th, 2006, 04:42 AM
Thanks for the reply. It's on a Fletcher 16ft and with a 17inch pitch prop. It was running fine but now started to play up so I had the carbs cleaned and checked but no better also put new plugs in. It's hitting 5500-5800 max rpm but taking a long time to hit to the rpm. Thanks
  #4
Old June 9th, 2006, 06:51 AM
studlymandingo's Avatar
studlymandingo studlymandingo is offline
Is it possible you have some water in your hull or maybe some saturated floatation foam? If it performed well with the same setup before, then most likely something has changed, water is a common culprit.
__________________
The wetter, the better.
  #5
Old June 9th, 2006, 06:56 AM
Texasmark's Avatar
Texasmark Texasmark is offline
I'd start with a decarb. I recently purchased an '02 3 cyl 90 and after decarbing it ran much better.On your rpm with that prop, unless your boat is REAL heavy, or the hull covered with crud, you should be running well over 6000 which is a further indication of the engine not performing correctly. That engine has a 2.3:1 gearbox so it swings a much higher pitch than a lot of engines with the more standard 2:1.I am running a 24P on that same engine on a 17' aluminum bass boat and still the rpm's are at 5600.....just to give you some idea as to where you are. But my boat only weighs 750# dry, is padded, lightly loaded, with just me.If decarbing doesn't help you should investigate a fuel starvation problem, like a clogged fuel filter somewhere in the fuel delivery line and then have the timing checked for proper advance at WOT.HTH,Mark
  #6
Old June 9th, 2006, 02:28 PM
Thanks for tips. I have put a new fuel filter and lines. When I put a 19inch pitch prop on it lowers the revs still down to 4300rpm max and still slow. I put new plugs in and it went great but second time out stated to play up again so I tried another set of plugs but it didn't help?
  #7
Old June 11th, 2006, 09:21 AM
Texasmark's Avatar
Going to a higher pitched prop is the wrong direction till you get the engine cleaned up.It's putting more load on the engine experienced by your drop in rpm's from those you ran with the 17. After it gets to running correctly then go to another prop, if that's what you feel you need to do, but I don't have a problem with your 5800 rpm's with the 17 which would give you a much better hole than the 19.WOT operating range is 5000 to 5500 and I'd much rather be running over the high end rather than around or below the low end.If you put in new plugs andit ran great, you just ID'd your problem. Gungied plugs.So how'd they get that way? Either fouled out from too much fuel (sticking/ maladjusted float in the carbs) or the engine is carboned up.You need a decarb job......which will help free up any sticking float problems. Go to SEARCH herein and find out how to do it. Then come back and tell us what's going on.Mark
  #8
Old June 11th, 2006, 09:23 AM
Texasmark's Avatar
One thing I forgot, you could have problems in your fuel tank also....dirty filter (in it) or crud, moisture, rust, blobs of goo from moisture dispersants you may have put in there, bad fuel.Mark
  #9
Old June 11th, 2006, 03:03 PM
Hi Thanks very much for the tips. I should have explaned better. I was running a 19inch prop last year and it was hitting 5500-5800 rpm but I want to start Wakeboarding so I got a 17 for better towing. Now with the 19 prop it's only hitting 4300 but with the 17 it hits 5500. I bought a brand new plastic fuel tank, new filter so dont think it's them. When you say decarb what do I need to do? sorry to askThanks again
  #10
Old June 12th, 2006, 06:30 AM
roger3645 roger3645 is offline
Go to the FAQ of the forum and read the Decarb information posted by Roscoe this should help clear things up for you. Decarb is a procedure to remove carbon build up inside the motor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
slow out the hole dennisrhall Mercury & Mariner Outboards 5 October 16th, 2004 06:46 AM
1998 Force Mercury 90HP Stalls at Slow Speed Oldsaltydog Force & Chrysler Outboards 3 May 23rd, 2004 10:39 PM
1998 Mercury 90HP Stalling at Slow Speeds Oldsaltydog Mercury & Mariner Outboards 7 May 23rd, 2004 10:12 PM
slow out of the hole dig Yamaha & Suzuki Outboards 2 January 7th, 2004 11:26 AM
Mercury 150 outboard slow out of the hole imported_fish_on Mercury & Mariner Outboards 3 July 23rd, 2002 01:56 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
