seascavanger
- Aug 14, 2005
- 9
Great group guys!<br />I would like to know if I can use a digital engine analyzer for a temporary tach. Its a small "alltest" that measures amps,ohms,volts,dwell and tach with 2 thru 8 cyl switch. 4 wires include (positive and negative)and(red and green)....instructions for tach: "connect red test lead to negative terminal of the coil,select cyls,switch to tach,read rpm" <br />Will I short anything out by using these automotive directions? <br />Its a 1970 merc 1350. Does 55mph WOT after link-n-sync. She's runnin so good Im scared to short anything until I find a compatible tach.
