  #1
Old May 31st, 2006, 02:46 PM
Crappiefishing Crappiefishing is offline
Default Oil and Gas Leak on 90hp Mariner
I have a 94 90hp Mariner, I notice that in the back of the boat under the motor there is oil and gas mixture leaking from the engine, can anybody help with this? I thought it was just oil leaking from the top of the oil tank but I notice it's a mixture of oil and gas. Thanks
  #2
Old May 31st, 2006, 03:57 PM
Laddies Laddies is offline
Default Re: Oil and Gas Leak on 90hp Mariner
If the engine is tilted up without runnig the fuel out of the carb they will drip I don't know if this is the problem or the inlets are sticking
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old June 2nd, 2006, 01:13 PM
sport15 sport15 is offline
I have an '87 70hp Merc that does the same thing.. I reviewed the FAQ, only found "its a poor design and you have to run the gas out", searched online and then was told by a local dealer "Mercs always do that.." Not the best answer. So, I took a piece of IV tubing and stuck it onto the overflows and led the ends up higher then the top of the bowl on the respective carbs. This stopped the leaking over flows with the engine tilted but now it makes the oozing main jets more obvious. All the floats are set and inlets are clean.If the IV trick helps great, if not, as Red Green said, "we're all in this together".. Anyone else got an idea?Dave
  #4
Old June 3rd, 2006, 08:38 AM
mtnriverdog mtnriverdog is offline
I recently received a lot of help from the forum on my '95 125 merc. This what I did to stop the exact same problem. Replaced the bottom gasket on the air intake cover, bought a transom saver to keep the motor lower instead tilting all the way up and when I take out I tilt the motor all the way up with the motor off and then right back down. This seems to let any unspent fuel run out of the carbs and then down to the drip pan. Everybody told me that any merc they ever saw or owned did this.MDOG
  #5
Old June 3rd, 2006, 08:40 AM
One more thing. Several people have told me to disconnect the fuel line while the motor is running and let it run out of gas. I have not tried it. Any comments?MDOG
  #6
Old June 4th, 2006, 08:17 AM
MdogRunning the gas out worked too... Then you read in other sections of the forum and the boys say to be careful of that 'cause if one jug goes dry first then it is getting no oil.Not that helpful but there you go.JB, what say you?Dave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 90hp Johnson Oil Leak BCHBUM Johnson & Evinrude Outboards 0 May 25th, 2005 08:10 AM
90hp silencer box leak nboater Mercury & Mariner Outboards 4 August 17th, 2004 02:59 PM
'82 90hp carbs leak bullyt Mercury & Mariner Outboards 1 July 28th, 2004 05:24 AM
1991 90hp mariner and 1994 115hp mariner JC1933 Mercury & Mariner Outboards 4 January 12th, 2004 09:38 AM
1991 90hp mariner and 1994 115hp mariner JC1933 Force & Chrysler Outboards 1 January 11th, 2004 06:38 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
