Re: Reverse lock on 1981 Mariner not interlocked
It is a manual lock using the lever. There would be no reason to keep going back to lock and unlock it. With the lever in the down position (Locked), you would run the boat normally and if you hit something with the lower unit, it is designed to break free of the locking mechanism. The only time you would need to use the lever, is when you are tilting the motor up for shallow water operation or trailering. Hope this covers it.....
__________________
Rick
"Boating is Life...All the rest is just Details"
