  #1
Old May 28th, 2006, 10:05 AM
djbdjb djbdjb is offline
Default 1999 Mercury 4 stroke 40hp low power and stalling
I'm re-posting in hopes that someone can help.I bought this boat (16' Key Largo) used, it had been sitting for about 6 months. The motor starts and idles fine, but stalls and/or bogs down when the throttle is opened. It also stalls when moving from full throttle to idle speed. It doesn't want to run well in mid throttle range and has problem getting on plane. I emptied the fuel tank and put fresh gas in, no better. I took it to a Mercury dealer, they put it on the computer, but found no problems. They vacuumed and synched the carbs. When I got it back, it was 50% better, but it still stalls when throttle is pulled back and has no power in mid rpm range. Once it reaches top speed it runs well, it's just difficult to get it there.
  #2
Old May 28th, 2006, 12:35 PM
ronnieboy ronnieboy is offline
Default Re: 1999 Mercury 4 stroke 40hp low power and stalling
my 2000 30 hp did the same thing, had to remove caps on carb adjustment and enrichen all 3 carbs. merc mechanic said he couldnt do it cause of polution restrictions, drill out cover cap and back out screws 1/4 turn and try it. hope this helps , ron
__________________
me and forest , we be mates, 374vee
  #3
Old May 28th, 2006, 12:37 PM
by the way, what size and pitch prop are you running on your motor? mine is a 10 1/4 x 14 pitch.
__________________
  #4
Old May 29th, 2006, 06:57 AM
Thanks for the reply, I'll look into the carb adjustment. I'm running an SS 10 3/8 x 13.
  #5
Old May 29th, 2006, 08:00 AM
I don't see the caps to drill out, where are they located ?
  #6
Old May 29th, 2006, 09:38 AM
look on carb body, they are bout 3/8 of an inch, and brass , be carefull not to drill to deep, will screwup a lot of stuff , if to deep. adjust very little, good luck ron
__________________
  #7
Old May 29th, 2006, 12:19 PM
the plugs are very thin and 1/16 deep should do it.
__________________
  #8
Old November 4th, 2009, 07:37 AM
I just realized I never put any closure to this thread (3 years later).
After many return trips to the mechanic the problem was clogged jets in the carbs and prop that was not sized for the boat correctly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Idle problem Mariner 40hp 2 stroke 2cyl. 1999 Surfistar Mercury & Mariner Outboards 1 June 17th, 2006 08:20 PM
1999 4 stroke 40hp low power and stalling djbdjb Mercury & Mariner Outboards 0 May 22nd, 2006 07:11 PM
1999 Yamaha 40hp with loss of power at full throttle riverghost Yamaha & Suzuki Outboards 3 June 30th, 2005 10:54 AM
2000 40hp 4 stroke Mercury stalling/surging problems entropy Mercury & Mariner Outboards 0 July 19th, 2003 02:17 PM
Mercury 40hp stalling when throttling up liamcast Mercury & Mariner Outboards 0 June 21st, 2002 02:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
