  #1
Old May 27th, 2006, 07:03 PM
Crappiefishing Crappiefishing is offline
Default Mariner 90 hp leaking oil from oil tank
I have a 94 Mariner 90hp Motor, The oil seems to be leaking out of the top of the oil tank, oil tank not overfilled, checked cap/cover not cracked, cover is screwed in tight. Can anybody help with this problem. Thanks
  #2
Old May 28th, 2006, 06:23 AM
Texasmark's Avatar
Texasmark Texasmark is offline
Default Re: Mariner 90 hp leaking oil from oil tank
Yes. Get a new gasket and lid...comes in a kit from Merc and not too expensive. When you install it, push the lid firmly down before you start screwing it in and only screw it finger tight...don't romp on it. Then two things:1. Don't fill it all the way up and 2. Don't leave your engine tilted more than you have to....like when it is stored, put the engine vertical. That will reduce the pressure on the seal. Probably don't have to do this step but what the heck. Doesn't hurt anything.BTDT and mine works fine now. Mark
  #3
Old May 28th, 2006, 02:37 PM
Quote:
Originally posted by Texasmark: Yes. Get a new gasket and lid...comes in a kit from Merc and not too expensive. When you install it, push the lid firmly down before you start screwing it in and only screw it finger tight...don't romp on it. Then two things:1. Don't fill it all the way up and 2. Don't leave your engine tilted more than you have to....like when it is stored, put the engine vertical. That will reduce the pressure on the seal. Probably don't have to do this step but what the heck. Doesn't hurt anything.BTDT and mine works fine now. Mark
  #4
Old May 28th, 2006, 02:38 PM
Thanks I will try that.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Gas Tank leaking! Please Help! lappin Boat Restoration and Building 5 August 31st, 2006 12:06 AM
Gas leaking from from ext. tank connector Wiggy Mercury & Mariner Outboards 3 June 18th, 2006 08:23 AM
leaking built in tank scottcaulfield Boat Topics and Questions (not engine topics) 7 April 10th, 2004 07:18 AM
leaking built in tank scottcaulfield Yamaha & Suzuki Outboards 1 April 4th, 2004 01:06 PM
Leaking fuel tank olddeeds Non-Repair Outboard Discussions 1 May 7th, 2002 02:08 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
