  #1
Old May 22nd, 2006, 05:07 PM
john licausi john licausi is offline
Default 1969 Mercury 125 Spark Plug Problem
I recently acquired a 1970 Glasspar G-3 with a 69 Merc 1250 engine on it and was able to simply change the spark plugs and fire it up during the winter. The engine seemed to run fine. Since then, I changed the Mercontrol lever to the new chrome lever that Overtons carries. I pulled the key switch out of the Mercontrol and mounted it on my dash.I am now turning the key and the engine is turning over, but there is no spark at the spark plugs. I am not sure what I did. The engine is moving, it is just not igniting. Any help is appreciated.
  #2
Old May 23rd, 2006, 08:48 AM
roger3645 roger3645 is offline
Default Re: 1969 Mercury 125 Spark Plug Problem
Was the battery disconnected when you changed the key switch around? CHeck the switch box with a volt meter. You should have power to the red post with the battery connected and power to the white post with the key on.
  #3
Old May 23rd, 2006, 11:52 PM
Thank you for your help. The battery was disconnected. I never actually changed the wiring on the switch or anything like that. I simply unscrewed the Mercontrol box and pulled the key switch out and screwed it as is onto the dash. I didn't cut a single wire. I simply removed the switch and cluster of wires from the Mercontrol. All wires remain in tact from the key switch to the plug connecting to the engine.
  #4
Old May 24th, 2006, 03:21 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
what did you do with the neutral switch.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old May 27th, 2006, 07:04 AM
I found the problem. It was the actual starter switch. Some wires were bad. She purs now!!! Thanks for the help. It is appreciated!
  #6
Old May 27th, 2006, 10:50 AM
phatmanmike phatmanmike is offline
the nuetral safet switch wont kill out the ignition, it kills out the starter selenoid.glad to here ya got it!now go get a danmed manual!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
trying to figure out this spark problem 1969 115 evinrude capt quint Johnson & Evinrude Outboards 1 August 22nd, 2004 02:52 PM
1969 Evenrude Spark Problem rogerrabbitis Johnson & Evinrude Outboards 2 July 15th, 2003 02:25 PM
1969 Mercury 350 weak voltage to spark plug lifeandliberty Mercury & Mariner Outboards 4 July 6th, 2003 06:28 AM
1969 Evenrude Spark Problem rogerrabbitis Non-Repair Outboard Discussions 0 June 30th, 2003 04:34 AM
1969 evinrude triumph 55 spark problem mochamedics Johnson & Evinrude Outboards 0 June 29th, 2003 09:40 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
