10 years ago I lost a 25hp mariner off the back of my boat. This spring I found the motor (totally by accident)and have managed to get the motor running! The only issue I'm having is a MAJOR rich condition at idle. At full speed it runs flawless. <br /><br /> I bought a gasket kit for my carb (WMC 45)and have spent hours cleaning it up, I feel that my problem might be an internal carb issue but I really need more opinions. So far I have checked the timing, adjusted the float, checked the reeds, new plugs and set the idle screw back 1.5 turns (from seated) The only way I can keep the motor idleing is too open the butterfly up, when I set the mixture screw and idle set screw to factory it stalls. ANY help you may have would be greatly appreciated!
