  #1
Old May 7th, 2006, 02:27 PM
bht-kevin bht-kevin is offline
Default '87 Mariner - Low power when cold, then kicks in
I have an 87 Mariner 75 HPBesides running a little rough at low RPM or idle, its hasnt had any problems. The past two times we took it out, it has what seemed like 1/2 the power it normally would for quite some time. After running it for about 15 minutes, the full force of the power kicks in and it nearly yanked my head back. After that, I didnt have a single problem with rest of the day. This has happened now on back to back trips so I guess its time to figure it out. On the second trip ( this morning )it was half speed and then it died. Anytime I would try and increase the RPMs from low to higher, it would die. I unplugged the fuel supply and re-attached and then pumped the fuel again and let it sit for a while. It started back up then and ran half speed for about 5 minutes before full KICKED back in and I was flying again. Worked great the rest of the day but still seemed rough at low speeds.Any ideas?This is my first boat, so please me gentle
  #2
Old May 7th, 2006, 02:34 PM
Default Re: '87 Mariner - Low power when cold, then kicks in
Serial is 0B1102201
  #3
Old May 7th, 2006, 02:57 PM
elkhunter1971 elkhunter1971 is offline
I had the same problem, do the sea foam concentrate. your jet is probably sticking. I have had no problems since.
  #4
Old May 8th, 2006, 06:42 AM
studlymandingo's Avatar
studlymandingo studlymandingo is offline
have you tried cleaning the carbs yet?
__________________
The wetter, the better.
  #5
Old May 8th, 2006, 09:52 AM
I haven't tried anything yet. I think my first step is to buy a repair manual. I know nothing about motors, but I guess I soon will Thanks for the tips! I am going to try the seafoam thing first. That is basically going to flush out my fuel system?
  #6
Old May 8th, 2006, 09:55 AM
Is this the one I need?Mercury/Mariner Outboard Tune-Up & Repair Manual Mercury Outboards, 2-40hp, 1-2 Cyl. 1965-1989Mercury Outboards, 40-115hp, 3-4 Cyl. 1965-1989Mercury Outboards, 90-300hp, 6 Cyl. 1965-1989
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1966 Johnson 9 1/2 hp, kicks out of gear as I increase power newuserguy Johnson & Evinrude Outboards 12 April 8th, 2006 07:41 AM
40 hp mariner mag 4 cyl--oil&cold start hooksetter62 Mercury & Mariner Outboards 3 May 19th, 2005 09:07 AM
15 HP Mariner - Cold Performance Case Mercury & Mariner Outboards 2 February 17th, 2002 04:49 PM
mariner cold start flatsman Sailing 1 August 21st, 2001 11:55 AM
Cold natured Mariner and OB oils Toontime Mercury & Mariner Outboards 2 June 8th, 2001 03:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
