Engine seizure cause?
badboyod
Hi,<br /><br />I have a 98 Mercury outboard 150, 4 stoke EFI that is seized. It had plenty of 4 stroke oil etc. What would be the most likely cause? Thanks in advance. john compton
JB
Re: Engine seizure cause?
1998 150hp 4 stroke Mercury??? Please edit as required to get it right, John.<br /><br />Most likely causes of siezure in 4 strokes are overheat and loss of oil pressure.
badboyod
You we're right it was a 2 stroke and the cause is apparently that my son allowed the injection oil container to empty. So, now the question is should I consider a rebuild for 5k or skip it and replace it? Worried about a rebuild on s seized motor. Should I be?
LubeDude
Originally posted by badboyod:<br /> the cause is apparently that my son allowed the injection oil container to empty
How did that happen, Is your son Deff? My opologies if he actually is). There is an audible warning horn that should have raised all kinds of H*ll when the oil ran low. If not then it is as much your fault as his for not making sure this system was opperating properly.
