  #1
Old April 26th, 2006, 07:13 AM
bigmac50 bigmac50 is offline
Default 1962 Kiekhaefer Mercury Merc 60 6hp
Having problems with this old reliable outboard. Had been running great until last fishing trip. It started fine but will not throttle up, just kinda putts in gear. Turn it off and wait awhile and it may run good for just a minute or two and then goes back to doing the same thing. Everything appears to be OK inside but I have noticed gas dripping off the bottom of carb. Any suggestions would be appreciated. Thanks in advance.
  #2
Old April 26th, 2006, 09:21 AM
Motor Boater Bill Motor Boater Bill is offline
Default Re: 1962 Kiekhaefer Mercury Merc 60 6hp
Could be a bad coil, I had this problem with my 1962 Merc 110. Run it until the problem starts, then pull one spark plug wire at a time. If pulling one plug wire does nothing, that cylinder isn't firing. Of course, check points and condenser also. You could swap condensors and see if the problem moves to the other cylinder. If not, then it's probably the coil. Available at oldmercs.com. If removing the plug wires one at a time doesn't reveal the problem, then it may be fuel. Try pumping the bulb when it bogs down and see if that helps. If so, it may be the fuel pump.Let us know how it goes.
  #3
Old April 26th, 2006, 10:29 AM
Thanks Bill, I'll check that out. About the bulb, if I pump the bulb while it's running it goes dead. That's why I thought it maybe the carb.
  #4
Old April 26th, 2006, 10:39 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
I'd disassemble the carb and check for a sticking needle/float. Sounds like it's letting too much fuel through, as is apperent when you pump the bulb and it dies....Clean all the passages as well while you're in there...
__________________
Rick
"Boating is Life...All the rest is just Details"
  #5
Old April 26th, 2006, 07:31 PM
Yup, if it dies when you pump the bulb your float valve is definitely not working properly. This could be source of the problem or it may be in addition to electrical problems. Checking for spark is still a good idea, but be careful if you have gas leaking for sure!!! Fix the carb, and take it from there.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1960 Mercury Kiekhaefer 400 beavis331 Mercury & Mariner Outboards 4 October 3rd, 2006 12:39 PM
What year Mercury Kiekhaefer 650 wiserboy Johnson & Evinrude Outboards 2 September 28th, 2003 04:38 AM
Kiekhaefer Mercury 7.5 identification Bearcamp Mercury & Mariner Outboards 0 May 22nd, 2003 01:10 PM
KiekHaefer Mercury jacksonceo65 Mercury & Mariner Outboards 3 June 23rd, 2002 09:19 PM
Kiekhaefer Mercury year ? twotone Mercury & Mariner Outboards 4 May 10th, 2002 08:31 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
