1984 Mercury 50 HP #6539486.Starts and idles fine.But when pushed to WOT it starts to increase but just bogs and after about 1-2 min.it dies but starts back up ok.Top speed is only about 6 mph.Ran comp check=120 on all 4 cyl.Check gas filter in screw cansiter seemed white and clean.Top carb has WMA3-1 and bottom carb has WMA3-3.Fuel pumps is on the side of carb and is square.Are these the right carbs and year 1984 on title? Tried pumping bulb at WOT no help thanks.Tried new port.fuel tank and same.Plese help! Plugs= NGK BUHW
