I recently purchased a 76 Starcraft with Mercury 850. The boat ran fine prior to selling it to me, and after sitting a few months. My first trip to the lake was not good. The boat would idle fine but under power would not get up and go. Prior to purchasing the boat I found out that he had taken the prop off and forget to replace the thrust washer. There did not appear to be any damage. My question now is..if you put the shifter into forward gear should you be able to turn the prop freely or should there be some compression from the engine?
