water pump problem 9.9 bigfoot
swiftsure
I have a 2002 9.9 Mercury exlh Bigfoot sail power with a gear ratio of 2.42:1. I went to start it after being down for a few months the other day and no water so I shut it down immediately. I have taken the thermostat out and blown through the hose to the tell tale and it is free and clear. I boiled the thermostat and it's good. I left the thermostat out and tried it and no water. I then dropped the lower unit and checked the impeller, looked good to me, no breaks or charring. I gave it a good cleaning and put it together and no water. Is my water pump toast? The last thing I did was dropped the lower unit and tried to blow up the water line in the leg, I could not. Does this mean that something is blocking the passage or are you not supposed to be able to blow up that line? Thanks in advance for any help.<br /> :confused:
Kiekhaeferscurse
Re: water pump problem 9.9 bigfoot
"Does this mean that something is blocking the passage or are you not supposed to be able to blow up that line? Thanks in advance for any help."<br /><br />Sounds like you figured it out all by yourself, if you cant pass air you cant flow water
swiftsure
Thanks Kiekhaeferscurse, I pulled the side cowling off and where the water tube goes into the block there was an obstruction. Cleared the obstruction and was able to blow through. I replaced the impeller anyway jus to be on the safe side, alot cheaper than replacing a motor.
