  #1
Old April 11th, 2006, 03:15 PM
gungho johnny gungho johnny is offline
Default Mariner electrical problem update.
I have tried to check the power coming into the motor. From the positive terminal the wire goes to what appears to be a "coil". From ground to that terminal I have 12v. Form the other terminal on the "coil" in which a wire goes to the starter, I have nothing. I tried to ohm it out and it appears to be open, no continuity, and no resistance. Any suggestions?
  #2
Old April 11th, 2006, 03:28 PM
Silvertip Silvertip is offline
Default Re: Mariner electrical problem update.
The coil you mention is not a coil -- its the starter solenoid which acts like a very heavy duty switch. The ignition key in the start position sends 12V via the small wire on the solenoid. This actuates the solenoid which makes a physical connection between the two large posts which then feeds 12V to the starter. Because the starter draws a very large amount of current, the ignition switch would fry in a heartbeat if it had to pass that current. The large post on the solenoid that has the positive battery terminal on it should measure 12V as you discovered. The other large post that connects to the starter will have 12V on it only when the key is in the start position. If it doesn't either the solenoid is bad, the ignition switch is bad, or the wiring between the solenoid and the switch is bad.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
5.7 is driving me crazy, Electrical Problem? (UPDATE) ktoy Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 40 August 28th, 2005 09:44 PM
Mariner 20 electrical problem/fire ballen9898 Mercury & Mariner Outboards 0 August 1st, 2005 08:20 AM
92' 90hsp mariner electrical issue myket1 Mercury & Mariner Outboards 3 September 19th, 2004 03:10 PM
1997 Mariner 40 H.P. electrical question S.T. Marine Mercury & Mariner Outboards 1 August 16th, 2003 07:18 PM
97 Mariner 225 Offshore electrical problem? steveayoub Mercury & Mariner Outboards 0 May 5th, 2002 04:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
