I concluded my rectifier was bad..<br /><br />I had the same voltage not running and running at about 2500 rpm.. <br /><br />I purchased the radio shack full-wave bridge rectifier rated for 25amps.. I installed it and now when idled up to 2500 rpms I go from 12.6v to 13.4 volts.. Which seems to atleast be charging a little, and I would also assume at higher RPM's I will get a higher output. <br /><br />My question.. The rectifier is getting really hot. Is this normal? It looks like the old rectifier was mounted to the block providing a great heat sink. Should I worry?
