Pee hole question .. 68 Merc 650
robpoe
Fired up the old girl for the first time in over a year. Had it in a full trash can of water. It took around 5-10 seconds before it started peeing. At idle it streams out (about 2-3" then falls), at ~3000 rpm it pees out ~7 inches before it arcs and falls. At a very (very) low (sputtering low) idle, it drops off and just dribbles out. <br /><br />Is this a good sign, or do I need worry? Is anything out the pee-hole at idle good? Do I need to expect a 20" stream?<br /><br />Thanks in advance!!!
Limu1222
Re: Pee hole question .. 68 Merc 650
You may want to replace impellor. Its cheap and could save your engine.It is not that hard to replace.
robpoe
How does the trim tab come off? I see the other 4 bolts. Is this something I _NEED_ the manual for, or if I disassemble / reassemble in the same way .. ???
PuckHog
There should be a plug in the case just above the trim tab. Remove the plug and way down in there is a 3/8" allen head cap screw. If it's anything like the trim tab on my '69 650, it'll be a bear to turn. Definitely get a manual.
timmathis
You should change impeller. At idle it should pee pretty good not 20''.
