Okay, here is what I have done. Carb kits (2), new plugs, new water pump kit, new fuel pump kit, new fuel lines/primer bulb, new gas. <br /><br />I cannot get the dang thing to idle. I have worked those idle screws (in water) every which way and cannot get the thing to idle. I have to use the warm-up lever (which revs it) then QUICKLY pull it down and put in gear to get it to do, otherwise, it dies.<br /><br />Also, once I get going, it will go for a while, then die and not start unless I squirt starter fluid in the carbs (the only way I could get back to shore, so had too!). <br /><br />After warming up, as soon as I put the warming lever back down....dies. No amount of adjusting on the idle screws/mixture screws works. <br /><br />I replaced the floats, needles, gaskets on the carbs. I don't see anyway to "adjust" the floats. Any suggestions are appreciated. U can also email me w/suggestions at sfarrisrn@aol.com. Thanks!
