1980 115 6 cyl. Changed the rectfier now the tac. don't work, changed back to the old one still don't work. The reason I changed it was because of a mis which turned out to be a plug. The trim will not raise while under pressure but works fine other wise, did I put a wire on wrong? Would they be caused by the same thing?
