  #1
Old March 29th, 2006, 03:44 PM
buzzer1 buzzer1 is offline
Default 1989 50hp Mercury oil in exhaust plug fouled
Hi Guys,I am new here and need help.I have a 1989 Mercury 50hp outboard that is giving me a headache. One of the cylinders on the thing keeps cutting out and fouling out. There is also oil in the exhaust leaking from the hub. The carbs have been cleaned and tuned, the spark has been checked and seems strong. I can start the motor and run it at full throttle on the other cylinders very slow and bogging and then it will just kick in clear out and go like hell. Then after a period of just trolling or going slow it cuts out again. Anyone got any suggestions? Do you think it could be a coil? Also the alarm keeps going off during this solid beep indicating overheating. Any help would be appreciated.
  #2
Old March 30th, 2006, 04:50 AM
Laddies Laddies is offline
Default Re: 1989 50hp Mercury oil in exhaust plug fouled
It sounds like the switch box, whats the way they seem to go
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old April 4th, 2006, 01:02 PM
Here is what I did this weekend. I started the motor and disconnected the bottom cylinder plug wire, no change. I put it back on and disconnected the middle cylinder plug wire, engine stumbled. I put it back on. I then disconnected the top cylinder plug wire and engine stumbled. Next I took the middle cylinder coil and swapped it with bottom cylinder coil. I started the engine and removed bottom cylinder plug wire still no change. I removed middle cylinder plug wire motor stumbled. This eliminates the coil as the problem. Here is where it starts to get tricky. I pulled the plug wire on bottom cylinder and could see and hear the spark to the plug, but no change in engine cylinder definately not working (I'm thinking spark is too weak). Then I rev the engine up and try to change the situation. Next thing is I pull top cylinder plug and no stumble. Now the top cylinder has no spark. I pull bottom cylinder plug wire no change. Engine is now running on only one cylinder the center cylinder. I am thinking that the only thing that could cause this condition is the switch box. The part is $185 new from the parts store. I do not have a dva to test but was wondering if it sounds like the switch box to you experienced folks. Carbs are clean as a whistle and fuel is flowing nicely. Any help would be much appreciated and I will continue to post resolution in order to help others. Thank you.
  #4
Old April 4th, 2006, 04:33 PM
Yes it sure sound like the box, the stator is working or it wouldn't run at at and triggers rarely fail
__________________
  #5
Old April 4th, 2006, 06:16 PM
KCLOST KCLOST is offline
As I posted in your other post, I'm worried about the overheat alarm you are having...That doesn't sound like it could be related to a switchbox failure.. An intermittent beep maybe (if you have oil injection) but a constant beep has me stumped...You may very well have an overheat problem.. And overheating the engine can cause the switchbox to fail... Or I guess I should say, a failing switchbox can quit functioning properly with higher temps...Let us know...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What exactly is a fouled plug kenimpzoom Non-Boating Technical Topics 9 October 7th, 2004 06:21 AM
Oil fouled spark plug MrBill PWC (Jetskis, Waverunners, etc.) 1 September 7th, 2004 04:08 PM
fouled plug alaskaduck Non-Repair Outboard Discussions 2 June 16th, 2003 11:06 AM
For Fouled Plug. harrison20002 Non-Repair Outboard Discussions 1 February 2nd, 2002 10:04 PM
Hey fouled plug Yepblaze Other Outboard Brands 1 July 15th, 2001 09:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
